Islandracer.com Message Board
Go Back   Islandracer.com Message Board > For Sale and want to buy on all Islands
FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 08-20-2016, 10:44 PM
Needmorepower Needmorepower is offline
Junior Member
Default Toys
FOR SALE 1983 Camaro RACE CAR
355 four bolt main 11.1 compression 1.94 Heads 64cc flat tappet cam with Comp cams roller rockers brodix intake 700 cfm 4150 with hooker super competition headers griffin radiator electric water pump.
Msd pro billet distributor accel super coil msd two step 7AL box,dedenbear throttle stop,electric shifter,throttle stop timer,shift timer,tilton super starter and all auto meter gauges starting line control.
Power glide Reid Case
Blue clutches
Kolene steels
Kevlar band
Steel shaft
Steel hub
Tci pro tree trans brake
Tci deep pan aluminum
Tci 8 inch converter 5,500 stall
B&M pro stick
12 Bolt
Four link
Mark Williams axle & spool with 35 spline steel caps with 5/8 wheel studs.Koni shocks.
Weld raceing draglite front & back.
32x13x15 on the rear
KEVIN 357 5961 15,000.00
  #2
Old 10-17-2017, 02:11 PM
Junior Member
Default
bump
  #3
Old 10-20-2017, 11:26 AM
FARIASRACING FARIASRACING is offline
Senior Member
Default Aluminum Intake
Stage 2 Aluminum Intake fits 351 windsor new in the box.
SUM-226036 $175.00.
870-0318 DJ
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
