Islandracer.com Message Board
Go Back   Islandracer.com Message Board > For Sale and want to buy on all Islands
FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 07-21-2019, 11:47 AM
erikk erikk is offline
Junior Member
Default 615 Aluminum Block Motor
"New" Shafiroff 615 Drag Race Motor
Brodix Aluminum Block 10.2" Deck Height
Brodix Headhunter 395 M.C. CNCd Cylinder Heads
T&D Shaft Rocker System
Raised Cam Tunnel with Shafiroff Proprietary Camshaft
Bronze Lifter Bores With .904 Lifters
Edelbrock Super Victor Ported Intake Manifold
Callies Crankshaft 4.625 Stroke
Callies Steel Rods
Diamond Pistons 4.600 Bore 15-1 Compression
Holley 1250 Carb
MSD Crank Trigger Ignition
Moroso Vacuum Pump
Meziere Water Pump
Moroso Oil Pump and Oilpan
Approx. 1100 H.P.
Price $20,000
The motor has zero runs on it. Motor was installed in a dragster and started up several times but has never taken a pass down the dragstrip. The motor was purchased brand new from Shafiroff and delivered to Maui 2013-2014.
Also available matching 9" A1 Torque Converter with zero passes.
Call text Erik 808 357 0472.
Size:  141.6 KBName:  20190719_082832.jpg
Size:  128.5 KBName:  20190719_084256.jpg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
